查看: 425|回复: 0
TQ210 —— s5pv210 cmd_board.c分析
发表于 2018-3-30 09:54:47 | 显示全部楼层 |阅读模式
[cpp] view plain copy
  • * (C) Copyright 2000-2003
  • * Wolfgang Denk, DENX Software Engineering, wd@denx.de.
  • * See file CREDITS for list of people who contributed to this
  • * project.
  • * This program is free software; you can redistribute it and/or
  • * modify it under the terms of the GNU General Public License as
  • * published by the Free Software Foundation; either version 2 of
  • * the License, or (at your option) any later version.
  • * This program is distributed in the hope that it will be useful,
  • * but WITHOUT ANY WARRANTY; without even the implied warranty of
  • * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  • * GNU General Public License for more details.
  • * You should have received a copy of the GNU General Public License
  • * along with this program; if not, write to the Free Software
  • * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
  • * MA 02111-1307 USA
  • * Misc boot support
  • #include <common.h>
  • #include <command.h>
  • #include <net.h>
  • /* Allow ports to override the default behavior */
  • __attribute__((weak))
  • unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[])
  •     return entry (argc, argv);
  • int do_go (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
  •     ulong   addr, rc;
  •     int     rcode = 0;
  •     if (argc < 2) {
  •         cmd_usage(cmdtp);
  •         return 1;
  •     /************* farsight **************/
  •     char *commandline = getenv("bootargs");
  • // 获取内核参数数据结构地址
  •     struct param_struct *lht_params=(struct param_struct *)0x20000100;
  •     printf("setup linux parameters at 0x20000100\n");
  •     memset(lht_params,0,sizeof(struct param_struct));
  •     // 传递物理内存页大小
  •     lht_params->u1.s.page_size=4096;
  •     // 传递物理内存页数
  •     lht_params->u1.s.nr_pages=0x10000000>>12;
  •     // 传递内核参数
  •     memcpy(lht_params->commandline,commandline,strlen(commandline)+1);
  •     printf("linux command line is: \"%s\"\n",commandline);
  •   // 获取内核启动地址argv[1]="20008000"
  •     addr = simple_strtoul(argv[1], NULL, 16);
  •     printf ("## Starting application at 0x%08lX ...\n", addr);
  •     /************** farsight *************/
  •     __asm__(
  •         "ldr    r1, =1826\n"                                    // 传递machine type id(arch number)
  •         // 关闭TLB/icache
  •         "mov    ip, #0\n"
  •         "mcr    p15, 0, ip, c8, c7, 0\n"
  •         "mcr    p15, 0, ip, c7, c5, 0\n"
  •         "mcr    p15, 0, ip, c7, c5, 6\n"
  •         "mcr    p15, 0, ip, c7, c10, 4\n"
  •         "mcr    p15, 0, ip, c7, c5, 4\n"
  •     // 关闭mmu
  •         "mrc    p15, 0, ip, c1, c0, 0\n"
  •         "bic    ip, ip, #0x00002000\n"
  •         "bic    ip, ip, #0x00000007\n"
  •         "orr    ip, ip, #0x00000002\n"
  •         "orr    ip, ip, #0x00000800\n"
  •         "bic    ip, ip, #0x00001000\n"
  •         "mcr    p15, 0, ip, c1, c0, 0\n"
  •         // 跳转到内核
  •         "mov pc, %[zImage]\n"
  •         // 清空流水线
  •         "nop\n"
  •         :[zImage]"r"(addr)
  •         :"r1"
  •     /**************** farsight ************/
  •      * pass address parameter as argv[0] (aka command name),
  •      * and all remaining args
  •     rc = do_go_exec ((void *)addr, argc - 1, argv + 1);
  •     if (rc != 0) rcode = 1;
  •     printf ("## Application terminated, rc = 0x%lX\n", rc);
  •     return rcode;
  • U_BOOT_CMD(
  •     go, CONFIG_SYS_MAXARGS, 1,  do_go,
  •     "start application at address 'addr'",
  •     "addr [arg ...]\n    - start application at address 'addr'\n"
  •     "      passing 'arg' as arguments"
  • extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
  • U_BOOT_CMD(
  •     reset, 1, 0,    do_reset,
  •     "Perform RESET of the CPU",
GMT+8, 2020-10-19 23:09
