查看: 464|回复: 0
TQ210 —— s5pv210 mem_setup.S分析
发表于 2018-3-30 09:55:40 | 显示全部楼层 |阅读模式
[cpp] view plain copy
  • * Originates from Samsung's u-boot 1.1.6 port to S5PC1xx
  • * Copyright (C) 2009 Samsung Electrnoics
  • * Inki Dae <inki.dae@samsung.com>
  • * Heungjun Kim <riverful.kim@samsung.com>
  • * Minkyu Kang <mk7.kang@samsung.com>
  • * Kyungmin Park <kyungmin.park@samsung.com>
  • * See file CREDITS for list of people who contributed to this
  • * project.
  • * This program is free software; you can redistribute it and/or
  • * modify it under the terms of the GNU General Public License as
  • * published by the Free Software Foundation; either version 2 of
  • * the License, or (at your option) any later version.
  • * This program is distributed in the hope that it will be useful,
  • * but WITHOUT ANY WARRANTY; without even the implied warranty of
  • * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  • * GNU General Public License for more details.
  • * You should have received a copy of the GNU General Public License
  • * along with this program; if not, write to the Free Software
  • * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
  • * MA 02111-1307 USA
  • #include <config.h>
  •     .globl mem_ctrl_asm_init
  • mem_ctrl_asm_init:
  •     ldr r0, =0xe6000000 /*APB_DMC_BASE*/
  •     ldr r1, =0xe0000000 /*PRO_ID_BASE*/
  •     ldr r2, [r1]        /*PRO_ID regiser*/
  •     bic r2, #0xfffffdff
  • /******************** DLL initialization **************************/
  •     @ldr r1, =0x6a101000
  •     ldr r1, =0x50101000
  •     str r1, [r0, #0x18] /*PHY control 0 register*/
  •     @ldr r1, =0x000084f4
  •     ldr r1, =0x000000f6
  •     str r1, [r0, #0x1c] /*PHY control 1 register*/
  •     ldr r1, =0x00000000
  •     str r1, [r0, #0x20] /*PHY control 2 register*/
  •     @ldr r1, =0x6A101002                @DLL on
  •     ldr r1, =0x50101002
  •     @ldr r1, =0x6A101003                @Dll start
  •     ldr r1, =0x50101003
  •     ldr r1, =0x50101001
  • /************************** DLL initialization - END ************************/
  •     @ldr     r1, =0x0FF01010            @auto refresh off
  •     ldr     r1, =0xFF001010
  •     str     r1, [r0, #0x0]  /*e6000000 = controller control register*/
  •     @ldr     r1, =0x00212400            @ BL=4 , 2 chip , DDR2
  •     ldr r1, =0xff202400
  •     str     r1, [r0, #0x4]  /*e6000004 = memory control register*/
  •     @ 128MB config , 8banks , linear, Row=13bit,COL=10bit
  •     @ldr    r1, =0x20F01313
  •     ldr r1, =0x20e00313
  •     str r1, [r0, #0x8]
  •     @ldr    r1, =0x40F01313
  •     ldr r1, =0x30e00323
  •     str r1, [r0, #0xc]
  •     ldr     r1, =0x20000000
  •     str     r1, [r0, #0x14] /*precharge policy configuration register*/
  •     @ldr     r1, =0x00100004
  •     @str     r1, [r0, #0x28]    /*precharge policy configuration register*/
  •     @ldr    r1, =0x0000050e
  •     ldr r1, =0x00000400
  •     str     r1, [r0, #0x30] /*AC timing register for auto refresh of memory*/
  •     @ldr    r1, =0x16233297         @TimingRow   @166MHz
  •     ldr r1, =0x16233287
  •     str     r1, [r0, #0x34] /*AC timing register for the row of memory*/
  • @;  ldr r1, =0x24250304         @CL=5
  •     @ldr    r1, =0x23230000         @CL=3
  •     ldr r1, =0x23240304
  •     str r1, [r0, #0x38] /*AC timing register for the data of memory*/
  •     @ldr     r1, =0x07c80232                 @Timing Power
  •     ldr r1, =0x09c80232
  •     str     r1, [r0, #0x3c] /*AC timing register for the power mode of memory*/
  • /************************ direct command for DDR2 ***********************/
  •     ldr     r1, =0x07000000                 @chip0 Deselect
  •     str     r1, [r0, #0x10] /*memory direct command register*/
  •     ldr     r1, =0x01000000                 @chip0 PALL
  •     ldr     r1, =0x00020000                 @chip0 EMRS2
  •     ldr     r1, =0x00030000                 @chip0 EMRS3
  •     ldr     r1, =0x00010400 @chip0 EMRS1 (MEM DLL on = DQS# disable)
  • @;  ldr     r1, =0x00000552 @chip0 MRS (MEM DLL reset) CL=5, Burst Length=4
  •     ldr     r1, =0x00000542 @chip0 MRS (MEM DLL reset) CL=3, Burst Length=4
  •     ldr     r1, =0x05000000                  @chip0 REFA
  • @;  ldr     r1, =0x00000452 @chip0 MRS (MEM DLL unreset) , BL=4 , CL=5
  •     ldr     r1, =0x00000442 @chip0 MRS (MEM DLL unreset) , BL=4 , CL=3
  •     ldr     r1, =0x00010780                  @chip0 EMRS1 (OCD default)
  •     ldr     r1, =0x00010400 @chip0 EMRS1 (OCD exit)  Reduced Strength
  • /************************ direct command for DDR2 - END*******************/
  •     @ldr     r1, =0x00FF20B0            @ConControl auto refresh on
  •     ldr     r1, =0xff01030
  •     ldr     r1, =0x00100004
  •     str     r1, [r0, #0x28]
  •     @ldr     r1, =0x00212413                @ MemControl
  •     ldr     r1, =0x00202400
  •     str     r1, [r0, #0x4]  /*e6000000 = controller control register*/
  •     b   exit_cpu_init
  • exit_cpu_init:
  •     mov pc, lr
GMT+8, 2020-10-24 14:48
