查看: 16413|回复: 0
java修改xml节点方法
发表于 2018-6-11 09:28:33 | 显示全部楼层 |阅读模式
1.最简单的修改[html] view plain copy
  • import java.io.FileOutputStream;
  • import javax.xml.parsers.DocumentBuilder;
  • import javax.xml.parsers.DocumentBuilderFactory;
  • import javax.xml.transform.OutputKeys;
  • import javax.xml.transform.Transformer;
  • import javax.xml.transform.TransformerFactory;
  • import javax.xml.transform.dom.DOMSource;
  • import javax.xml.transform.stream.StreamResult;
  • import org.w3c.dom.Document;
  • import org.w3c.dom.Element;
  • import org.w3c.dom.NodeList;
  • public class Test {
  •     public static void main(String[] args) {
  •         try {
  •             DocumentBuilderFactory dbf = DocumentBuilderFactory.newInstance();
  •             DocumentBuilder db = dbf.newDocumentBuilder();
  •             Document doc = db.parse(XmlUtil.getCurrentPath());
  •             NodeList list = doc.getElementsByTagName("entry");
  •             for (int i = 0; i < list.getLength(); i++) {
  •                 Element ele = (Element) list.item(i);
  •                 String brandName = ele.getAttribute("key");
  •                 if (brandName.equals("outRoot")) {
  •                     ele.setTextContent("${user.dir}/generator-output/123");
  •             TransformerFactory transformerFactory = TransformerFactory.newInstance();
  •             Transformer transformer = transformerFactory.newTransformer();
  •             DOMSource domSource = new DOMSource(doc);
  •             // 设置编码类型
  •             transformer.setOutputProperty(OutputKeys.ENCODING, "UTF-8");
  •             StreamResult result = new StreamResult(new FileOutputStream(XmlUtil.getCurrentPath()));
  •             transformer.transform(domSource, result);
  •         } catch (Exception ex) {
  •             ex.printStackTrace();
2.稍微不一样的
  • import java.io.Console;
  • import java.io.File;
  • import java.io.IOException;
  • import javax.xml.xpath.XPath;
  • import javax.xml.xpath.XPathConstants;
  • import javax.xml.xpath.XPathExpressionException;
  • import javax.xml.xpath.XPathFactory;
  • import org.w3c.dom.Node;
  • public class XmlUtil {
  •     public static void main(String[] args) throws IOException {
  •         modifySon("test");
  •     public static void modifySon(String newPackage){
  •         DocumentBuilderFactory dbf=DocumentBuilderFactory.newInstance();
  •         dbf.setIgnoringElementContentWhitespace(true);
  •         try{
  •             DocumentBuilder db=dbf.newDocumentBuilder();
  •             Document xmldoc=db.parse(XmlUtil.getCurrentPath());
  •             Element root = xmldoc.getDocumentElement();
  •             System.out.println(root.toString());
  •             Element per =(Element) selectSingleNode("/properties/entry[@key='outRoot']", root);
  •             per.setTextContent("${user.dir}/generator-output/"+newPackage);
  •             TransformerFactory factory = TransformerFactory.newInstance();
  •             Transformer former = factory.newTransformer();
  • //            former.setOutputProperty(javax.xml.transform.OutputKeys.DOCTYPE_PUBLIC, xmldoc.getDoctype().getPublicId());
  •             former.setOutputProperty(javax.xml.transform.OutputKeys.DOCTYPE_SYSTEM, xmldoc.getDoctype().getSystemId());
  •             former.transform(new DOMSource(xmldoc), new StreamResult(new File(XmlUtil.getCurrentPath())));
  •         }catch(Exception e){
  •             e.printStackTrace();
  •     public static Node selectSingleNode(String express, Element source) {
  •         Node result=null;
  •         XPathFactory xpathFactory=XPathFactory.newInstance();
  •         XPath xpath=xpathFactory.newXPath();
  •         try {
  •             result=(Node) xpath.evaluate(express, source, XPathConstants.NODE);
  •         } catch (XPathExpressionException e) {
  •         return result;
  •     public static String getCurrentPath(){
  •         String path = XmlUtil.class.getProtectionDomain().getCodeSource().getLocation().getPath();
  •         String rootPath = path.substring(1,path.length()-5)+"/src/test.xml";
  •         return rootPath;
特殊:其中xml文件中有DTD声明修改后没了
注意其中2句代码
根据声明类型计入对应的忽略设置
北京万邦易嵌科技有限公司(www.wanbangee.com)专业提供单片机、M3/M4linuxAndroidQT技术服务、技术培训。
GMT+8, 2020-11-25 04:42
